Need some help please....
Old Feb 10, 2006 | 11:12 PM
yankeesfan81's Avatar
Alright well first off I have an 04 F-150 Styleside XLT 4.6 4x4 AT 3.55 factory 6cd/mp3. Well I was on my way back to the store when my stereo just shut off completely. I have had that happen to me before in other cars so I just shut it off and turned it back on hoping it was fine. But the stereo didnt turn on!!! I have lights to the stereo but no visual screen or sound coming out.. When I got back home I took the stereo out to make sure all connections were fine.. and they were..I even checked the fuse for the stereo, which was fine as well.....
So to make sure that it wasnt the stereo I went inside to grab the factory single cd player that came with the truck.. Put that in and still no visual screen or sound..
The 6cd/mp3 deck let me eject all of the cds that I had inside so there was power... and after I took the last cd out I hit eject disk one more time and " no disk" showed on the screen... but quickly went away...
At this point I have came to the conclusion that the cd players are fine because neither of them work.. so it has to be something with the truck or wiring..
I am going to take it down to the Ford Dealership tomorrow morning but I was just wondering about your thoughts on it..
Thanks guys
Matt
Old Feb 12, 2006 | 12:10 AM
anyone have any ideas...
Old Feb 12, 2006 | 12:29 AM
Red05stx's Avatar
Possibly a loose ground. Shure you checked the right fuse? change it anyways.
Old Feb 12, 2006 | 01:10 PM
Alright well I swapped out both fuses, #7(start signal) and #31(radio power) and I also check #41 (cig lighter)
And still not working.....
any other ideas.. I also made a post in the stereo section and someone said soemthing about a bad ground.. Where would I check the ground?
Anyone else have any ideas...
Old Feb 12, 2006 | 03:09 PM
98Navi's Avatar
Also check for something getting mashed in the back power wise that could be grounding out. Are your door speakers stock or aftermarket? One more thing, there are two power wires......A constant hot and an ignition on wire. If one of those isn't getting power to the unit, or is less than +12V then your radio will not work. Get a test light or a voltmeter and test for the hot wires. The test light will burn brightly, andt he voltmeter will obviously read around +12V.
If you can't pinpoint them, post it here and tell me which radio the truck came with, if it has a 6 disc external cd player, etc etc (all the radio options) and I'll get you a diagram.
Old Feb 12, 2006 | 05:38 PM
Alright well I dont have time right now to go check that. But thanks for the idea..
Pretty much my truck came with single cd/fm radio.. just the basic CD player..
Old Feb 12, 2006 | 10:18 PM
bump for Navi... Thanks for your help man...
Old Feb 13, 2006 | 12:10 AM
98Navi's Avatar
I can't remember my alldata logon. I'll get back to you tomorrow when Ihave that info at work, sorry for the delay. College, malted hops and bong resin have clogged my brain and shot my memory
Old Feb 13, 2006 | 08:27 AM
98Navi's Avatar
Few other things, makes a difference if yoy have a Screw, or if you have a subwoofer. This is the basic version, without rear seat entertainment package
Old Feb 13, 2006 | 10:56 AM
I have regular cab... no sub..
Old Feb 13, 2006 | 12:15 PM
GIJoeCam's Avatar
If the CDs will load/eject, it sounds to me like you lost the switched power source to the deck. Not sure offhand where it's fed from, but that's where I'd start.
-Joe
