voltage drops across the battery
Old Jan 25, 2006 | 03:26 PM
gspman's Avatar
I have a 93 f150 xlt, 302ci, at, awd
I have developed an issue in the charging system. When at idle and heavy electrical load, the voltage drops across the battery. Running Idle no-load is about 14.5v - 14.8v, Running at idle, full load starts at 14.5v and after a couple of minutes will drop to 12 to 12.5 volts. To the very point where windshield wipers get real slow, headlight go dim.
Ignition off- battery voltage is right at 12v. I have cleaned connections and battery posts.... I am at a loss in what to do next!!!
Old Jan 25, 2006 | 04:44 PM
projectSHO89's Avatar
Alternator isn't working very well.
Take it out and have it tested. Replace if necessary.
Steve
Old Jan 25, 2006 | 08:46 PM
98Lariet4x4's Avatar
I agree. Altenator woes...
Old Jan 26, 2006 | 02:55 PM
gspman's Avatar
voltage dropping
Sorry
I failed to mention that i just replaced the alternator 3 days ago???????
I am going to get my jumper cables out tmro and parallel the baterry cable under full electrical load. Maybe a bad cable
Old Jan 26, 2006 | 04:31 PM
tex_n's Avatar
I'd bet money on either bad connections or bad cables.
Old Jan 27, 2006 | 08:28 AM
Just because the alternator is new doesn't mean it's good...... Measure its output at the alternator.
There is a 12 Ga fuse link between the output of the alternator and the battery. If it blows or goes tyo a high resistance, you won't get proper charging.
Steve
Old Jan 27, 2006 | 03:55 PM
frostby's Avatar
OR...
Measure the voltage drop from the alternator to the battery. There shouldn't be one. If there is, you've found your defective cable.
