Running Light Indicator
Old Jan 18, 2006 | 01:30 PM
Night Runner's Avatar
Ok help. I just noticed that my running light (fog light) indicator is not working. The lights do work. I pulled out the switch and can see the LED. I have no problem pulling the switch apart.Does anyone know the rating of the LED? From looking at the schematics I believe it is 12 volts as it runs in parallel with the light circuit.
Old Jan 18, 2006 | 04:19 PM
SSCULLY's Avatar
The generic box for the fog lamp section of the Main Light switch, shows a resistor in series with the LED. There is no value for the resistor, so I could not take a guess at what ratting is for the LED.
If you are going to take apart the switch, just get a 12 V LED, and remove the resistor from the circuit. On the trace, you would need to scratch the trace away from the resistor, and solder a jumper over it, or try to make the pins on the LED go to before the resistor, and the ending point.
Maybe trying to take a resistance reading from pin 2 to pin 6 on the Mainheadlamp switch ? Can't recall if this will work or not, but it might.
Pin 2 is the White with a black stripe wire, and pin 6 is the black wire.
Pins 2 & 6 are on the lower row of 6 pins, where the alightnment pins are for the connector hood.
Good luck, that might be a trying case to pull the switch apart, and solder in a new LED.
Old Jan 18, 2006 | 09:29 PM
Thanks I think Not sure if its better to try to repair of buy a switch. Again thanks. Also good spot I missed that resistor.
Any one else have any experience I will not be working on this till the weekend.
Old Feb 9, 2006 | 04:22 PM
Well pulled the switch apart and one of the dang LED legs had come loose. Not soldered from the factory. I resoldered the leg and the light works. Thanks to all that gave me advice.
