Removing door panel
Removing door panel
I have a door ajar problem. The light blinks on/off and makes that beep sound. I have lubed the switch from the latch and that will help about 2-3 hours. I need to pull the door panel and remove the switch to do it right, but I cannot figure out how. I don't want to break any clips. Any help would be great, or a link to directions would be better! Thanks, Ron
To remove the trim pannel depending on the style of trim there should be two or three screws to remove. There should be a small piece of trim to remove on yhe front of the door post and ther should be a screw behind it if it has power windows remove the switch and there is a screw in that area if manual widows remove crank handle check lower edge of door pannel may have screws there may not then lift UP on pannel do not pull out or away from door. Pannel lift up toward window glass and then pulls away from door the clips are L shaped plastic pieces molded to the pannel. Very easy to remove after finding screws.
