Intermitant Brake Lights and cannot put truck in gear from park
Old Dec 26, 2005 | 03:12 PM
jloeem's Avatar
I have a 1997 F150 Lariat. The tail lights work for about a second when stepping on the brake petal and then go out. The truck cannot be placed in park when started or you will never get it into gear unless you happen to catch the 1 second window. The only way to start the truck and be able to put it in gear is to start it in neutral. Is this two seperate problems or one problem with many symptoms..Any thoughts?
Old Dec 26, 2005 | 05:19 PM
FrankLee's Avatar
Check for a broken wire on the brake light switch on the brake pedal lever.
Old Dec 26, 2005 | 07:28 PM
98Navi's Avatar
The shifting is due to one of two possible conditions.
1) Brake switch failure
2) Shift Lock Solenoid failure
The brake switch is much more likely the fault. Also, if you simply turn the key towards the on position, but not quite on (the lights will not be illuminated on the dash) then you can by pass it all and go to N to start it up and shift into R and D with no problem until you get it fixed.
Old Dec 26, 2005 | 09:41 PM
jloeem's Avatar
Thank you. I will check those out.
Old Dec 28, 2005 | 03:56 PM
GIJoeCam's Avatar
Indeed, it's the brake on-off switch, or at least that's where I'd put my money.
$10 part, 5 minutes to swap it out.
-Joe
Old Dec 29, 2005 | 08:42 PM
jloeem's Avatar
It was a broken wire on the brake switch. Thanks to all that posted info.
