Seatbelt Alarm!!
Old Dec 22, 2005 | 01:02 AM
mkpaige45's Avatar
Seatbelt Alarm!!
I know on the older f150s you can just push the seatbelt buckle to turn off the alarm but on the new ones there is no other way to turn that alarm off. Has anbody cut the wire to turn off the alarm permanently. If so which ones do you cut?
Old Dec 22, 2005 | 02:42 PM
KICKINWING's Avatar
i can disable mine by pushing the seatbelt buckle ........mine is a 02 supercrew.... what year do you have that will help someone get you a awnser
Old Dec 22, 2005 | 03:02 PM
Ponyboy24's Avatar
If yours is a newer model (04-05) inside the owners manual, there is a section that tells you how to turn that feature off. You have to insert and take off the belt a certain amount of times while the key is in the "on" position. Let me know if you don't have the manual and I can check the details.
Old Dec 22, 2005 | 03:33 PM
brydoc007's Avatar
I know this has been discussed I just can;t remember the post. do a search I think it is 9 times or 10 times in a minute???? try the search or wear your seatbelt
Old Dec 22, 2005 | 03:36 PM
H345's Avatar
I have followed the directions in the manual ( my dealer has also tried ) and no one is able to shut off the seatbelt alarm . I wear the belt when I am driving on the street , but I do a lot of stop and go on private property and it is a nuisance . I understand the plug is under the dash near the data port - what color is the wire ? I will unplug the wire or the alarm if necessary . Thanks .
Old Dec 22, 2005 | 04:06 PM
FX4_Guy's Avatar
I'd take it back to the dealer and tell them you want it fixed. Its their problem not yours. You shouldn't have to cut wires because when you follow fords directions it doesn't work.
Old Jan 17, 2006 | 04:52 PM
jchod's Avatar
So has anyone been able to turn the alarm off in an '06 with any success??
Old Jan 19, 2006 | 11:19 AM
boomerzuma's Avatar
I followed the directions in the owners manual and was able to turn the alarm off for the passengers side. I've tried to do the same for the drivers side but it hasn't worked & I've tried it several times....dang thing. BTW, I have an 2005.
Old Jan 19, 2006 | 11:23 AM
FX4_Guy's Avatar
If it is still under warranty...take it to your dealer and tell them to fix it.
Old Jan 19, 2006 | 11:27 AM
boomerzuma's Avatar
I'll give it one more try & if fails to work I'll have the dealer fix it. I need to take it in anyway for some warranty work. The black lettering on the F150 badges is flaking off......go figure.
Old Jan 19, 2006 | 11:35 AM
FX4_Guy's Avatar
I read about the black lettering flaking off in another thread...that reminds me, I need to go out and check on mine.
Old Jan 20, 2006 | 01:57 AM
memLT-1's Avatar
Belt Alarm
The only alarm you can turn off is the one that comes on after you drive awhile.The first alarm you hear is the one telling you to buckle up.You cannot overide it.On my 06 SCrew I had to turn the key to run wait untill the red seat belt quit blinking then buckle and un buckle the belt 9 times within 50 seconds.Then watch the yellow air bag symbol flash I think four time then buckle and unbuckle one more time.Worked good.
Old Jan 20, 2006 | 03:27 PM
boomerzuma's Avatar
Yep, that's the routine. It worked for my passengers seat but has failed to work for my driver seat.
Old Jan 23, 2006 | 06:27 PM
captain morgan8's Avatar
just go to a junkyard and get the buckle part and leave it plugged in, thats what I did.
