Right Blinker.....Dead End....??
Old Dec 19, 2005 | 03:33 AM
RedneckFord's Avatar
Question Right Blinker.....Dead End....??
Right turn signal blinks fast, indicating it is out obviously...
The front right is FINE,
but the rear right blinker, both back flashers, and the rear right brake light do not work.
I replaced the bulb, switched out the harnesses on each side, and checked the voltage across the faulty blinker. (seems to have some, maybe not enought to run it)
All the fuses are fine and I can not figure out where it is going bad, and i really don't want to bring it into the dealer.
I was hoping any of yall might have some ideas before I have to go digging throughout the whole truck to find out...
I noticed an earlier post with a 1999 XL f150 with the same problem. Did that solution work for you BLUEGRASS??
thanks a lot
Phil
