Power Windows Stopped
Old Dec 13, 2005 | 05:21 PM
cttony14's Avatar
Question Power Windows Stopped
My 1998 F150 power windows both stopped working today - of course I have them both open about an inch and it's cold as a @#$#@ in Connecticut.
I read thru other treads and looked at the Fuse under the hood (30A) - the fuse looks good. I also checked my manual but there is no fuse (under the dash) that relates to the windows. Everything else seems to be working fine(locks,dome light, etc). And the switch on both the driver and passanger don't work - so I am thinking its power issue - but can't pin point it.
Any ideas? Thanks for any help!!!
I just swapped out relay#4 and #5 - I was able to get the passanger window to go back up - but not the driver side. Going to the dealer tomorrow to try new relay.
Old Dec 13, 2005 | 10:41 PM
Bluegrass's Avatar
There is a GEM module involved.
Suggest you invest in a Haynes manuel and reference page 12-26.
All the circuit shown covers all the models so some of it won't be used on your 2 door truck. Only the left and right door part.
Good luck.
Old Dec 15, 2005 | 08:41 AM
cttony14's Avatar
Installed a new ACC Delay Relay - that fixed it.
