driver side power window
Old Nov 1, 2005 | 10:55 PM
kaptain's Avatar
so this isnt exactly electrical, but its the closest i could find to my problem: the driver side power window hass gotten progressiely slower going up, and when it is all the way up there is a rattle in the door panel. i can make the rattle stop if i quickly hit the down button for the window so that it only moves a little bit. because of this i know there is something wrong with the track for the window, but i dont know what. finally, a few days ago i got it partway down, but then i wouldnt go back up. i rolled it all the way down, and there was a "click," then it rolled up like normal. has anyone had a problem like this before? im planing on removing the interior door panel so i can look at the mechanism and see if i can fix it, but id like to know if there are any tricks (such as plastic fasteners) that i need to know about first so im sure not to break anything. thanks!
Old Nov 5, 2005 | 06:05 PM
xibbumbero's Avatar
Have you sprayed the track w/silicone spray? X
