locating wires
Old Oct 28, 2005 | 11:57 AM
countyboy04's Avatar
locating wires
I am trying to locate the proper wires for my alarm install. The instructions say that the door lock/unlock outputs should show a negative voltage when the lock/unlock button is pressed. At rest mine read around .05V and when the button is pressed read about .85V. Are these the correct wires? They are the only wires of that color in the door sill.
Old Oct 28, 2005 | 08:40 PM
BrianXLT's Avatar
Does your meter read -.85? Just a thought
Old Oct 28, 2005 | 09:44 PM
It reads a positive voltage.
Old Oct 30, 2005 | 07:50 AM
GPOjunk's Avatar
Which wires are you using?
Old Oct 30, 2005 | 04:08 PM
I think it was the pink/green, and pink/yellow. They were the correct wires because it works properly now.
