Turn Signals 1994 F-150
Old Oct 24, 2005 | 08:04 AM
MMoloney's Avatar
Morning folks;
My turn signals were on the blink (no pun intended) and eventually stopped working. I checked the fuse (7 in this case) and all o.k. I checked each light bulb all o.k. I removed the combination turn signal, windshield wiper switch and replaced it (stupid me, as this was not the issue and cost me $120 as I can not return electrical parts as per my local Ford dealer.)
I can go ahead and test the continuity on the switch to see if I can track dowen the exact wire to see if in fact it is burnt wire or somehitng along those lines.
Anyone got any other suggestions? (Outside of getting a new truck, I love my truck, man).
Regards,
Michael
Old Oct 24, 2005 | 03:27 PM
tex_n's Avatar
If none of them work, and you just wanna throw a few more bucks at it, replace the flasher. I'd start there anyway.
Old Oct 24, 2005 | 04:28 PM
colvin's Avatar
did you check to see if you had a source the main b+ comming into your fuse take a test light and poke into the top of the fuse where it has the tiny slits to see if you have a b+ coming in
Old Oct 27, 2005 | 11:09 AM
MMoloney's Avatar
Thumbs up 1994 F-150 Turn Signals Issue solved
Hello Tex_n;
Thanks for your input. This solved the issue. I should have asked sooner. Now my truck it going to look real weird with two (2) turn signal/wiper switches attached.
Regards,
Michael
Old Oct 27, 2005 | 12:28 PM
tex_n's Avatar
Good, hey, you can never have too many turn signal switches. Just leave one turned on to the left, and the other turned on to the right....
