wiring in scanner
Old Oct 6, 2005 | 03:59 PM
90ZXdriver's Avatar
wiring in scanner
I'm not really what to search for, so I'll just make a quick post. I have a police scanner that I want to hardwire to the truck and have it power on and off with the radio (i.e. scanner on in run, on , and acc position). Does anyine know how this can be done and what wire I can splice into or where on the fuse box. Thanks, John
Old Oct 6, 2005 | 04:39 PM
05supercrew's Avatar
Just wire up an inverter and plug it in.
Old Oct 7, 2005 | 11:24 AM
90ZXdriver's Avatar
The scanner runs on 12volt DC current, so there is no need for a inverter, and i'm going for the custon installed look, without wires everywhere or plugging into the cigarette lighter. So I want to hardwire it, but I just need to find a wire or fuse to wire it to. thanks
Old Oct 7, 2005 | 11:50 AM
bofer's Avatar
you can always pull the dash apart and wire it into the cig lighter, and then change the fuse to a larger fuse
Old Oct 7, 2005 | 01:18 PM
GIJoeCam's Avatar
That's ridiculous!! NEVER increase the size of the fuse.... You could easily overheat the circuit, melting the wiring.... NOT a good idea!!!
You can do it a couple of ways..... either piggy-back it onto the existing switched stereo wire, or use an existing switched source to trigger a separate relay which powers the scanner.
Now, that being said, mobile scanners in a motor vehicle are usually illegal in most municipalities. Might want to check with the local constabulary before doing this one....
-Joe
