Front Signal Light Bulb Replacement
Old Sep 16, 2005 | 01:34 PM
Teri A.'s Avatar
Howdy folks. I have a '98 F150. I read & read, and you have detailed how to get to the back signal light bulbs, but there is not detail on how to change the front ones. Please help.
Teri A.
Old Sep 16, 2005 | 07:21 PM
Yankee7985's Avatar
1. Open hood.
2. Look just to the outboard end of the headlight assy. under the hood area and you will see a small screw going diagonally towards the turn signal assy.
3. Remove screw with a 7mm socket.
4. Grasp turn/parking light assy. and pull forward. It slides out.
Old Sep 16, 2005 | 07:49 PM
Teri A.'s Avatar
Thanks Yankee, but there is no screw in that corner under the hood which requires a socket to remove. The one screw there needs a torque screwdriver, but when removed, nothing else moved. Will try again, maybe just need to gronk the plastic casing. Pretty tight in there, gotta love these compact full sizers!!
Teri A.
Old Sep 16, 2005 | 10:02 PM
Yankee7985's Avatar
You can use a torx driver or a 7mm socket. I used a socket. You need to get a good grip on the light and "PULL". It has two rails it slides on.
