enough power?
enough power?
i have a 96 1/2 ton ford, as of now i have added fog lights, one set of auxilary lights (two) and two small lights in my toolbox, they are all wired to the battery, i plan to add 4 more lights to my headache, will i have enough battery power and will a stock altenator have enough ***** to recharge the batery if i do run all the lights at one time
i would appreciate all comments
I would consider using a deep cycle battery with an isolator. The deep cycle will allow you to run the lights for a much longer time without risking the starting battery. The isolator will allow the second battery to be charged only when needed, by alternating the charge between the two batteries. Don't forget to use a relay to prevent the possibility of fire due to overheating wires or switches.
