Cruise Control will not work
Old Jul 16, 2005 | 04:14 PM
bart_r6's Avatar
I seem to lost my CC a few days ago..... I did the CC test and I get a confirmation blink , then i got one blink when i press the ON button, but that's where it stops. There is no blink when i press the RESUME button. Also there is no code that blinks at the end. I have already replaced the swich on the brake res with a new one.....but that didn't help.
Any suggestions.??
I have a 2001 super crew
THANKS
Old Jul 16, 2005 | 09:59 PM
chucks bp's Avatar
You must continue the test by pushing the buttons within 5 seconds of the previus button or it will leave selftest, If you are doing this properly then you either have a bad switch, wiring problem or a clockspring problem.
To test these switches manualy remove the connectoer at the cruisecontrol servo, install ohm meter between pin 5 and pin 6 lt blue wire with black stripe and dark green orange stripe when pushing coast you should see between 114 and 126 ohams set accel 612 to 748 ohms resume 2090 to 2310 ohmas and off less than 5 ohms.
Old Jul 18, 2005 | 05:26 AM
bart_r6's Avatar
cruise control
Thanks for the info chucks bp............i'll test the switches and see the ohms i'll get.
