Side Mirrors Remote Switch
Anybody have a ballpark figure for switch listed above??
I first noticed a problem when I couldn't move the Passenger's Side mirror to the right. Left side is okay. Checked on Driver's Side and have the same problem, so I think (I hope) it's just the switch. You love this power stuff Until it quits working
Seems to be a common problem. Other posts recommend squirting some WD40 into it. I tried that on mine but didn't work. After that, you can pop off the panel exposing the switch and see if the contacts are dirty. Mine weren't, but upon plugging them back together, everything worked fine!
Worst case, a new switch from Ford should be less than $20, and you can do it yourself. (Other posts at this site give you even more detailed info.)
