What am I doing wrong?
Old Jun 9, 2005 | 02:58 PM
jcc's Avatar
jcc
thank you bluegrass
Old Jun 9, 2005 | 03:20 PM
GIJoeCam's Avatar
Originally Posted by Bluegrass
GI, I know you not going to like this but testing continuity IS no different than checking resistance, in reaility, if you want to make it simple.
For example if a lamp continuity is tested with a voltage source and a voltmeter to measure that voltage thru the lamp, it is no different than measuring with the Ohm function in the meter that has it's own battery, internally and accomplishing the same thing but giving more information.
The lamp has resistance in either case.
Sometimes continuity testing will not show a resistance that is still to high to work in the circuit.
I also know all the differences.
Agreed. One hundred percent.
My argument was against the grammar.... It's 'checking for continuity' or 'measuring the resistance,' not 'ohming it out'. When you check for continuity, the resistance value doesn't matter, but yes, you check them both the same way when using an Ohmmeter. A test light will check for continuity only.
Just to be argumentative, you can check for continuity without checking the resistance (with a test light), but you cannot check resistance without continuity.
Boy, talk about this thread taking a left turn!
-Joe
Old Jun 9, 2005 | 03:26 PM
jcc's Avatar
jcc
I'M GETTIN A HEADACHE
Old Jun 9, 2005 | 03:43 PM
Bluegrass's Avatar
GI, it's your "pet peeve" that done the left turn. If you can do it so can I!
Done.
Old Jun 9, 2005 | 04:55 PM
raalden's Avatar
Account Deactivated at User's Request
Checking continuity with a METER means you are measuring resistance with a goal of 0 ohms. 0 ohms means continuity (short), a high ohm value means little or no continuity (open). Those of us who do this sort of thing for a living use the slang "ohming out" for simple continuity checks using a meter.
Now if you're not using a meter, the phrase "ohming out" doesn't make much sense, but you are still measuring continuity, it's just the indicator of 0 ohms is a light rather than a digital or analog readout.
Old Jun 9, 2005 | 04:59 PM
frostby's Avatar
Why don't you guys try "checking the voltage drop"? or check the "tongue tingle" effect
Old Jun 10, 2005 | 12:42 PM
dennisinmo's Avatar
I agree, "Ohming out" is a very common term and is understood what it means. I don't have a problem with the term. Like getting a Xerox of something.
