Stranded vehicle, module(?) behind fuse box clicking
Old May 29, 2005 | 06:16 PM
tuchy's Avatar
97 Expy, 5.4 L.
The vehicle tried to stall on me as I got to church. The next time I tried to turn it on the instrument panel lit up and then turned right off. When I pressed the unlock on the key fob the door locks started to bounce around but never fully moved and the alarm would not work right. I disconnected the battery for a while then hooked up the battery to my van in case that was a problem. After, when I turned the key to Acc, the panel lit up again for a couple of seconds then shut back off. The interior lights are now out and there is a box behind the fuse panel that is clicking. Thanks for the help.
Old May 29, 2005 | 10:00 PM
NKENN's Avatar
I had the same clicking on my 01 5.4L Excursion when the battery died.
