Gauge Cluster Question?
Old May 5, 2005 | 01:11 AM
FOXFLYBY's Avatar
I have a '97 f150 and want to replace my cluster with one from a '99 f150.
The new cluster has digital tach, while the old has anolog. Other than that, the clusters are pretty similar.
Will it work, and if so, is it a direct plug for plug exchange or will I need a special harness to adapt the two?
Thanks for any info!
Old May 5, 2005 | 02:03 PM
JMC's Avatar
JMC
25 Year Member
Different connectors. No pats system on old cluster. You will need a wiring diagram for both and make the connections by hand and then I am not sure it will work.
JMC
Old May 5, 2005 | 10:56 PM
DjThomasJ's Avatar
no on a guage cluster without digital will not work with a digital cluster.. if you want this for the tach you can get a 97-98 cluster that has a tach.. it should be a direct replacement.. but to have a digital one i think u'd have to rewire quite a bit and probably messes with the computer too
DjThomasJ's Avatar
Old May 7, 2005 | 06:20 PM
svt_sc_f150's Avatar
It will not work. The '99 and up clusters communicate with the PCM for the PATS. The 97-98 do not. You would need to change the dash harness, the cluster, the PCM, and much more.
Old May 9, 2005 | 02:07 AM
FOXFLYBY's Avatar
The reason I ask is that a few of my gauges lights are burned out so I was thinking about putting a indiglow overlay on until I came across these babies!
However they are for '99 and up. Check them out.
http://www.simcoltd.com/shop_online.htm
Old May 17, 2005 | 03:21 AM
bryanfeelsgood's Avatar
How do you remove the old one, I am not doing this, but I do have a serious problem with dust and other gunk behind that clear plastic...
I have tried pulling the piece behind the steering wheel, but I don't want to pull to hard...
