Broke the wire at bottom of ignition switch
Old May 1, 2005 | 11:43 AM
dave1911's Avatar
I was removing the shroud around the steering column on my 1999 F-150 to investigate why my turn signals would stop working when I would tilt my steering wheel down. Somehow I seperated the fine wire at the bottom ignition switch from the three progned flat wire that goes to a black module on the bottom of the steering column. I think this is part of the anti theft device. Anyway, I can't start the truck ( the engine just turns over) to get it to the Ford dealer which is 10 miles away. I'm I going to have to have it towed or is there a way I can bypass the system just long enough to start it and get it to the dealer? Or is this something I can by the part and fix myself?
Thanks you for any help.
Old May 1, 2005 | 10:57 PM
Exit's Avatar
You may have damaged the anti-theft transceiver module or "Halo Ring". This device recognizes the chip in the ignition key. If this is disabled, the engine will turn-over and no start. On the 2001 F150 it is located at the bottom of the cylinder lock, 1999 unknown - possibly the same location. This maybe a FORD only item.
