horn connections in steering wheel?
Old Apr 23, 2005 | 01:24 PM
b1keslddr's Avatar
does or can anyone tell me where the horn connection on or in the steering wheel is. my horn dont work and i cant figure out why. cruise control works so i assume clock spring is okay. but i dont know for sure. do i have to remove the steering wheel and airbag to check for the horn connection. i do not have a steering wheel puller. i have purchased an aftermarket horn so anyone got any ideas how to wire it in around my existing horn that does not seem to work. thanks for any advice you can give me.
nathan
Old Apr 23, 2005 | 03:46 PM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
Well before you tear into it to far... Tell us what you have tested so far.
Did you check the fuses under the dash and under the hood? Did you check the relay? Did you run a jumper from the (+) battery post staight to the horn to see if it would blow?
Old Apr 25, 2005 | 03:43 PM
SATX04F150CB's Avatar
Cool Wiring Harness
If possible could you e-mail the pdf for 04-05 radio in the f-150, & Subwoofer/Amp box, I am looking fo the "audiophile" information
since the dealers computer does not show the wire harness that connects the Audiophile HU to the Amp/Subwoofer.
My e-mail address is KFRANCO@SATX.COM
Thanks,
Old Apr 25, 2005 | 06:14 PM
PSS-Mag's Avatar
^^Ummm, I think you posted in the wrong thread... ^^
