gauges
Old Apr 14, 2005 | 08:14 PM
dakano's Avatar
gauges
does anyone know of a speedometer gauge that will pick up where the cluster leaves off. this harley gauge only up to 100mph
seems ridiculous. i would like to be able to put it in a pillar pod.
thanks in adv.
mike
Old Apr 15, 2005 | 01:26 PM
Bluegrass's Avatar
only thing that's rediculas is running 100 mph on the road in a 5000+lb. truck.
Sorry if you might not agree.
Old Apr 15, 2005 | 01:46 PM
dpostman's Avatar
I agree with Blugrass.
However, I have not tried this but if you put your odomeder in TEST mode and cycle to the speed calibration screen, it may go furtehr than the needle.
I know the question will come so here it is.
With your truck turned off, push in the Trip reset button and hold, start your truck and keep holding the button until the ODO reads "tESt" then release, press the button once at a time to cycle through the different tests/screens til you get to the Speed MPH and let her rip.
I hope this helps...
Dpostman
Old Apr 15, 2005 | 05:25 PM
dakano's Avatar
speed
you're right bluegrass but every now and then i get a little crazy on lonely straight aways. i'm 52 w/600hp what can i say i've lasted this long. still looking for the gauge though if you happen to see one.
thanks
mike
Old Apr 15, 2005 | 05:29 PM
dakano's Avatar
gauge
i don't have a digital gauge on my 2000 would that matter dpostman
thanks for the response
mike
Old Apr 15, 2005 | 07:15 PM
chucks bp's Avatar
I installed a 2003 harley cluster in my 2001 supercrew for those special occasions when 130mph is necessary. It was a direct replacement and looks great.
Old Apr 16, 2005 | 08:49 AM
dpostman's Avatar
Re: gauge
mike
No you don't need a digital gauge, just the digital Odometer. I Have an analogue gauge but a digital Odometer and the odometer is where you get the test readings from.
Dpostman
