Brake Lights Don't Work
Old Apr 5, 2005 | 02:49 PM
tobyw1019's Avatar
99 f150 5.4 2wd
134k miles...All 3 of my brake lights don't work. I've checked the fuses and bulbs. I purchased a brake light switch, but not sure if I have the correct piece. I looked up under the dash along the brake pedal arm and noticed an electrical connection there, but it doesn't look anything like the part I bought. I have perfomed a search on the issue here, but nothing states exactly where the part goes.
https://www.f150online.com/galleries...w.cfm?num=6843
There is a pic of the part I bought in my album. Thanks in advance for any assistance!
Old Apr 6, 2005 | 12:48 PM
tobyw1019's Avatar
All of my other lights work fine. The emergency flashers work, blinkers work, flashers work when the lights are on. Cruise control works fine...fuse #13 is not burnt, and I replaced it just in case
Old Apr 8, 2005 | 10:24 AM
dowdc's Avatar
I am having the same problem. I have notice that on the brake petal there are two switches. If I rotate the top switch the lights start working. I am hoping the switch is bad. When I get the switch out I will tell you if it looks the same. Let me know if you come up with a solution.
Old Apr 8, 2005 | 10:43 AM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
Did you check the fuses under the hood? But since it is both the high mount and the truck brake lights they are 2 seperate circuits and they share the brake light switch. There might be 2 switches on your brake pedal. One is the brake light the other might be cruise control. I hope this helps.
Old Apr 10, 2005 | 09:02 PM
Vidaman's Avatar
I'm pretty sure you got the wrong replacement brake switch. There should be a black plastic switch on the pedal pin shared with the brake pushrod. It will have a connector with 5 pins that is pointed down toward the floor. You should see a yellow cotter pin holding the switch and pushrod on the pedal pin. That's the brake switch. There should be a part number molded in something like XXXX-13480-XX. Take that number to the dealer.
You received an old 2-pin brake switch design that requires a different connector. I think they used those switches in older Fords. Hope this helps.
-Vidaman
Old Apr 11, 2005 | 07:09 PM
svt_sc_f150's Avatar
The switch you got is for the '98 and earlier models. Like Vidaman stated, it should be plastic with 5 pins not 2.
Old Apr 13, 2005 | 09:39 PM
tobyw1019's Avatar
Thx for help guys. I got a chiltons FINALLY and took the part off the truck and realized the same thing you've just mentioned with the wrong part! Back to the APS
Old Apr 13, 2005 | 11:02 PM
tobyw1019's Avatar
I have brake lights! I had to ask for a 2001 brake light switch before the 5 pin newer model came up on their system. Autozone & O'reilly have the same issue...
Old Apr 13, 2005 | 11:30 PM
PSS-Mag's Avatar
