radio
Old Mar 27, 2005 | 07:48 PM
lblair's Avatar
Angry radio
The other day my radio stopped working, 97 F150, stock stereo system, heck figured it was a fuse, no power to unit, checked fuse under dash all was good, did a continuity test on fuse all is good, Are there any other fuses located other than under the dash that would control the power to the radio? Everything else works fan, cig lighter, etc Also all the lights on the stereo panel come on except no power to unit Help?
Old Mar 27, 2005 | 07:55 PM
heybeermantx's Avatar
I know that a lot of electronics have internal fuses that have a long life, but do blow due to age. This might be the case for you....crack that thing open and see if there is a fuse inside the casing.
Old Mar 27, 2005 | 08:03 PM
lblair's Avatar
I have since pulled the stereo out and tried another one I had lying around and I got the same results no power to the unit, not sure if there is a relay or something that would control the power
Old Mar 27, 2005 | 08:18 PM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
There should be 2 power wires Constant (AKA Memory) and Switched.
Do both the constant power and the switched power have 12v to the stereo?
Old Mar 28, 2005 | 08:08 PM
lblair's Avatar
Pss-Mag
I will have to check that out tomorrow night after work, I am sure there must be another fuse under the hood possibly or a relay that has blown
