I guess Robert Johnson aka "Lighting Survey" got his wish...
Old Mar 23, 2005 | 09:40 PM
OE812's Avatar
...at least with my FF50 Hella driving lights. They just started blinking intermitantly so I had to disconnect them so I can diagnose. Anything in particular to start with?
Old Mar 23, 2005 | 10:14 PM
lees99f150's Avatar
bad ground. loose connection. relay acting up.
Old Mar 24, 2005 | 06:09 AM
OE812's Avatar
I'll check.
Old Mar 24, 2005 | 11:31 AM
SAJEFFC's Avatar
Oh no!! RJ is out there....tak'in over our lights!
Old Mar 24, 2005 | 11:47 AM
2stroked's Avatar
Another (related) problem I've had with Hella 550's in the past is a bad connection inside the lamp housing at the bulb. I now make sure both the hot and ground connections are well coated with dielectric grease. In your case though (with both lights blinking) I'd suggest you check the ground.
