Light problems
Old Mar 21, 2005 | 05:54 PM
mfournierr's Avatar
Exclamation Light problems
everything was working fine on the truck I picked up some flooring and after I unloaded it and drove away I lost my blinkers, Brake lights, license plate light. I checked the fuse and it look good any other suggestions???
Old Mar 21, 2005 | 11:01 PM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
Did you check the power distribution box fuses under the hood?
Old Mar 25, 2005 | 09:21 PM
KDT's Avatar
KDT
I had a slightly similar experience today. Driving home in late afternoon, I adjusted the steering wheel to a lower setting, drove the rest of the way home and noticed my right blinker wasn't working. I backed into the driveway, parked, and tried the other blinker, then the emergency flashers, and they wouldn't work. I was about to check the fuses when I remembered adjusting the wheel earlier. Clicked it up a notch and everything worked again. Put it back down, and they cut out again.........They now work, with the wheel set back up, but I'm a bit troubled why it's doing this.....
Kevin
Old Mar 25, 2005 | 09:34 PM
PSS-Mag's Avatar
KDT,
Yours is definatley a short in the steering column. This should probabley be addressed imediatly...
Old Mar 25, 2005 | 09:40 PM
PSS-Mag's Avatar
Check that the plug under the dash is securley connected. After that your likely looking at replacing the steering column.
Old Mar 30, 2005 | 06:29 AM
KDT's Avatar
KDT
I'll be checking into the plug today while I'm replacing the door lock actuator.
Thanks!!!
Kevin
