passenger side rear tail light
Old Mar 9, 2005 | 02:29 PM
katt68's Avatar
my rear taillight is not working?
the bulbs are good and the brake light,back-up lights are all fine. I tested the power to the socket and out of the 3 connections i got, 5 volts on one,12 on the other and one is ground . what could be the problem?
Old Mar 10, 2005 | 07:08 AM
cliles55's Avatar
I'd try replacing the bulb. 8 years old, might be time.
Old Mar 10, 2005 | 09:25 AM
katt68's Avatar
the bulb has been replaced
Old Mar 11, 2005 | 11:24 AM
2stroked's Avatar
I'd suggest that the 5 volt reading is your problem. Which wire did you get it on? If it's the tail light (as opposed to brake / directional) wire, that's where you need to begin your search. I'd suggest tracing that wire back and seeing where it drops from 12 volts down to 5. Good luck!
