Key pad
Hey,
I ordered a new drivers door handle with key less entry pad (ebay). The wiring is in the door. I hooked it up and plugged it in. It doesn't seem to have power. It doesn't light up, the unlock code doesn't work, nor does the 8,9 option to lock the doors. Any suggestions/knowledge of this?
Thanks Shawn
5 Jan, Now I even found the procedures to arm and disarm the system. With the key off, press the code in, then press and hold the 7-8, then press the 3-4, release the 7-8, then you should here a chirp followed by the horn....stil doesn't work! Is there something else that needs installed?
Shawn
Thanks Shawn5 Jan, Now I even found the procedures to arm and disarm the system. With the key off, press the code in, then press and hold the 7-8, then press the 3-4, release the 7-8, then you should here a chirp followed by the horn....stil doesn't work! Is there something else that needs installed?
Shawn
