Wire through the firewall
Old Jan 2, 2005 | 11:55 AM
WebbDogg's Avatar
Wondering where the best place to come through the firewall is? I just installed some foglights and want to install the switch in the cab.
I'm just not sure where the best spot is. any pictures or suggestions?
Thanks guys.
Old Jan 2, 2005 | 02:49 PM
chucks bp's Avatar
In my 2001 supercrew there was a rubber plug to the pasenger side of the steering colmn I just made a hole in yhe plug and use it for whatever you need to bring throgh the firewall . Look around under the hood for plugs you will not be able to see these under the dash as usualy the insalation covers them.
For a nice instalation buy the original ford headlight switch for fog lights all the wiring is in the truck and ends in two plugs one on either side behind the bumper, mahes easy and neet instalation. If you shop around you can buy the switch for about $40.00
