dash bulbs
Old Dec 29, 2004 | 08:42 PM
black98150's Avatar
dash bulbs
Own a 1998 F-150...need to replace a couple dash light bulbs...what is the procedure for replacing these?
thanks!!
Old Dec 29, 2004 | 10:20 PM
lees99f150's Avatar
basically take the trim away from the cluster. remove the cluster to gain access to the back. you will need to remove the headlight switch to get to a screw behind it. there is a special procedure to do this. turn the **** to on (all the way to the right) and pop it off. replace it on the post 180* off. (backwards) then turn it off (to the left). turn past the off and you will feel it move some springs and levers, now pull out the switch assy.
buy a haynes manual for directions and pictures.
