How to turn off "Service Engine Soon" light
I just heard back from Cavalier Ford here in Portsmouth, Va. The problem was some sort of sensor (I forget what it was called right now) but there was a service bullitin issued on it. The problem has been fixed and we can come pick up our Expedition at "NO CHARGE".
Merry Christmas from FORD AND
MELMAN
MELMAN
Every dealership has its pros and cons. Meaning, there are mental/physical road blocks everywhere. OURS is our service writing department.
USUALLY when a vehicle comes in, (at least to MY stall), and there is OTHER concerns that should be mentioned, (and this WAS a safety issue), it would have for sure been mentioned/written down and the service writer should have told you/asked you if you wanted further work/diagnosis done to see what was up.
Now, not knowing exactly where/what they did to your vehicle, I can't say whether or not they would have tripped over the same codes/same area. Granted, if they did a complete (look for codes), checking ALL the modules, the airbag codes would have/should have come up, BUT, if they just did the 4x4 module/gem, and didn't look any further, then not.
Again, every shop is different, but for that kind of stuff, WE/I for sure want to know that I didn't cause the concern, OR for sure if the problem pre existed.
My .002
Good luck.
My .002
Good luck.
I wish we had a good Ford dealership around here. I have a couple friends who work at the biggest dealership in my area so I get my truck in there pretty often to work on it (I do the work, I just get access to a bay, lift and what tools I dont have..) and whenever I do have a problem watching the entire shop come over to stare at it and scratch their heads is pretty funny. Once I was standing around talking to a friend and helping him put a rebuilt tranny into a Taurus and I heard the guy in the next bay say "What the hell is that? to which he was answered "I dunno" and a third voice "Get the hammer".
I love the guys at that place, great poeple, but I can say with complete honesty that if I ever had to have anything done to my truck I couldnt do myself I wouldnt take it there. I needed their help to pull codes as I didnt have a scanner or know how to use it so I enlisted their help. An hour and a half later I had like 9 codes. I thought my truck was on the verge of collapse or something, lol. Turns out they didnt perform the tests correctly. I got online and did some research and went out and pulled my own codes with a 5 inch length of wire, lol.
Anyway, I dont have anything overly constructive to add, I just wanted to say that so folks know to be wary. Just cause its a Ford dealership doesnt mean its safe, hehe. Some are great but ask around before ya choose where to send your vehicle.
[QUOTE=drag79stang;1507763]I believe we charge $30. for a basic 'read codes', (while you wait). That does NOT include any pinpoint testing, or further diagnostics.
WE also run oaisis, messages and find out if there are any pertinent messages dealing with that specific code at that same time.
And that is within a couple of minutes of you coming in the door.
(again, that's at OUR dealership).
I dont use a dealer unless I absolutely have to. My sister is a service manager at our local dealer and all they are trying to do is get sales because like salesman they get a bonus on what they sell. I will go by Auto Zone and have the code(s) read off and ask her what they are and what they mean. Also a local shop is not gonna charge you outrageous shop wages and sell you genuine parts at an incredible markup because they have to cover stocking costs or whatever they want to call it. The only work i will get done at a dealer is warranty work or a prepaid oil change.
Not that I"m flaming autozone (or any place that reads codes for free), (well, maybe I am a bit),
, but it'd behoove you to have it done at a ford/mercury dealership. THEY have the proper scan tool, and will have the PROPER hardware/knowhow, and will/should give you a better idea of what further needs looking at, and./or what follow thru (pinpoint tests), need to be done to find the fault/faulty part.
Again, could be a bad sensor, could be a wiring concern, could be something as simple as a pcm reflash, (WHICH, I'm pretty sure autozone (whomever), could NOT handle, OR would even have access to proper reflash hardware).
My .002
(I might be a bit bias being as I work @ a ford dealership tho).........
, but it'd behoove you to have it done at a ford/mercury dealership. THEY have the proper scan tool, and will have the PROPER hardware/knowhow, and will/should give you a better idea of what further needs looking at, and./or what follow thru (pinpoint tests), need to be done to find the fault/faulty part.Again, could be a bad sensor, could be a wiring concern, could be something as simple as a pcm reflash, (WHICH, I'm pretty sure autozone (whomever), could NOT handle, OR would even have access to proper reflash hardware).
My .002
