Need LED Wiring Help
Old Dec 2, 2004 | 11:55 AM
ghank's Avatar
I have a 12V LED I bought off of Ebay and I want to hook it up as a fake alarm. So basically it is supposed to turn on when I pull the key out. Any ideas on how to do this? I have searched to no avail.
Thanks in advance.
Old Dec 2, 2004 | 12:37 PM
Mattmanyam's Avatar
Positive lead to constant 12V, neg lead to ign. Ign lead usually shows ground when off, at least enough to run the LED. I would also recommend fusing both sides.
Old Dec 3, 2004 | 12:10 AM
TonyPTX's Avatar
Re: Need LED Wiring Help
Thanks in advance.
Is it a flashing LED or just a steady on LED. If it's a flashing LED, its just a matter of hooking up the LED to a something that has constant power w/ ignition OFF and no power w/ ignition on. There are many ways to do this.
If it's NOT a flashing LED, then it's probably more complicated than you're willing to handle...it involves building a time circuit to "flash" the LED on and off....and I would suggest you just buy another one of those packages that are pre-built.
Tony
Old Dec 3, 2004 | 11:55 AM
ghank's Avatar
It's the flashing kind. Do you know what wire has power on with ignition off on an 03 F150? Thanks guys.
Old Dec 3, 2004 | 12:05 PM
frostby's Avatar
Careful when wiring to the ign... I suspect that it does NOT show ground when off. If it did, remote starts would be having a big problem! DOUBLE CHECK FIRST!
btw...ign wire is darkblue/light green.
Old Dec 3, 2004 | 12:16 PM
ghank's Avatar
Where is the best place to tap that wire? In the column? So positive to that wire and just find a ground?
Old Dec 6, 2004 | 09:04 AM
Mattmanyam's Avatar
FROSTBY
It is not really a TRUE ground, but it should be enough to run his LED. (It will light the "ground" indicator of my Snap-On LED test light...)
