2003 supercrew foglight replacement?
Old Nov 25, 2004 | 12:27 AM
sloth7098's Avatar
Does anyone know if im able to replace my factory foglamps with silverstar 9006, and if they are compatable do you have to do anything to make them fit. I saw on another thread this morning that they will work with an 03 f150 screw so i went to autozone and bought them and they didnt fit. I had to trim the plastic so that i could get the wires connected, once i figured that out i couldnt get the bulb screwed into the fixture. Any suggestions.
Old Nov 25, 2004 | 08:00 PM
Bluegrass's Avatar
Why did you not use the same number on the original lamp and match up with the lamp you wanted to use?
Old Nov 29, 2004 | 11:06 PM
sloth7098's Avatar
Never mind i figured it out its 9005
Old Nov 30, 2004 | 12:27 AM
TonyPTX's Avatar
Sylvania doesn't make a 9145 bulb in the SilverStar product line.
Old Nov 30, 2004 | 11:38 AM
2stroked's Avatar
Yupper, the 9005's work with just a slight modification to one tab with a pair of diagonal cutters. You won't believe the difference. Slap in a set of Silverstar 9007 headlight bulbs with them and you'll feel like a new man.
Old Nov 30, 2004 | 06:44 PM
TonyPTX's Avatar
How about some Xenarc's instead I installed the kit from Sylvania the other day. If 9007ST SilverStars make you feel like a new man, then the Xenarc's must make you feel like a new "seaman."
T
