Wiring of Lariat heated captain's chairs
I have an '02 Screw Lariat with the heated captain's chairs. Does anyone have any wire color information for the heater modules, more specifically the on/off switch contacts?
I want to output a pulse from my remote starter (delayed by a few seconds) to kick on the seat heater.
Thank you,
Mike
Thank you,
Mike
There are two types of heated seats. One's Motorola and the other is Bosch.
On the Bosch- you need to apply 12v to the DG/VT wire at the switch. Same with the passenger side.
On the Motorola. The DG/VT wire needs to be grounded.
Each seat will have to be wired up separately.
To determine which system you have, check the polarity on the DG/VT wire when you activate the switch.
