1997 wiring diagram
Old Nov 19, 2004 | 05:33 PM
dreamsr's Avatar
Question 1997 wiring diagram
Needed urgently to complete work on my truck. The 4wd motor will not apply the reverse voltage so that it returns to 2wd. I need the wiring diagram to know where I can find the relay to check that, HEEELLPPPP!!!!
Old Nov 20, 2004 | 10:31 PM
Home skillet's Avatar
You need a new motor. There are contacts in the motor that go bad. You may try taking it apart and sanding them clean.
Old Nov 21, 2004 | 01:00 AM
DDan1967's Avatar
I don't know if this will help but the Sevice Manual states it is located behind the Center of the Instrument Panel.
Though it looks more like it's in the center of the dash from the Component Location View. (See Link) https://www.f150online.com/galleries...060-107154.jpg
Here is a link to the connectors that may help you too. https://www.f150online.com/galleries...060-107155.jpg
Old Nov 22, 2004 | 11:15 AM
dreamsr's Avatar
A thousand thanks
Thanks a million, will check that out Ddan
Old Nov 23, 2004 | 09:11 AM
dreamsr's Avatar
Larger???
DDan is it possible for you to scan that image any larger, when I print it I can't seem to read the text.
Old Nov 25, 2004 | 12:40 AM
DDan1967's Avatar
I scaned if full size. For some reason when I upload it to the Gallerys here it shrinks it down.
If you send me a message with your email, thru the link on my profile here or thru Yahoo Messenger. User ID DDan1967
I can send it to you full size
Doug
PS Just some additional info. From the image it looks like the relay is under the access panel in the top of the dash. (the depression that seems to serve no perpose)
