Moisture in Headlight
Old Nov 17, 2004 | 06:19 PM
KingDing's Avatar
My passenger side headlight has moisture in it and i was wondering what can be done to get the condensation out of there because i have had problems with lights that get moisture in them and the bulbs like to go bad. any help or advice would be greatly appreciaited.
Old Nov 18, 2004 | 02:25 AM
Pestco1's Avatar
Either the headlight bulb is not seated properly or the housing is cracked or broken. Will prob. need to investigate and poss. replace housing if it is damaged. only takes a small stone at highway speed to put a big enough crack to let moisture in. Good luck
Old Nov 18, 2004 | 08:42 AM
Rockpick's Avatar
Moderator &
Just as a sidenote, if you're still under warranty, this is something that would be easily addressed...
Old Nov 18, 2004 | 03:19 PM
KingDing's Avatar
Yea i have plenty of warranty left,(just bought truck) but i was seeing if this was something that is common with fords (first time ford owner) and there was an easy fix before i took it into the shop.
