will not charge
Old Oct 14, 2004 | 07:33 PM
rrosin's Avatar
i need help, fast, will not charge
i have a 1982 f150 w/351w
will not charge the battery. i changed the altenator and voltage regulator. the truck would start and run if jumped but no charge. i found some faulty wiring between the alt. and starter sol. and repaired. now there is no fire from the coil. it will not start.
what have i done, what should i do?????
Old Oct 15, 2004 | 10:01 PM
Tailgator's Avatar
Check those fusable links at the starter solenoid. Backprobe them with a 12 volt test lamp to make sure there is continuity.
Old Oct 18, 2004 | 11:50 AM
rrosin's Avatar
Talking problem found
i must have burnt the regulator at installation. it, in turn toasted the brainbox. new brain and reg, works great now. thankyou for the help
