turn signal blink faster
Old Sep 30, 2004 | 01:04 AM
crazycalbo's Avatar
Hey, is there a way to make the turn signal blink faster if there is can someone tell me how to do it, I have a 94 F150 XLT
Old Sep 30, 2004 | 11:32 AM
2stroked's Avatar
In a '94, assuming that your flash rate is unusually slow, all you have to do is replace the flasher unit itself.
Old Sep 30, 2004 | 08:45 PM
Florida-150's Avatar
Assuming it has always been slow and you just want it faster....if you add a resistor in line with the bulb it will speed it up. might be a pain to do but it should speed it up. A one ohm resistor is probably what I would start with and go from there....
Old Oct 4, 2004 | 07:57 PM
TonyPTX's Avatar
Maybe upgrade it from a Thermal Flasher to an Electronic Flasher?
Old Oct 13, 2004 | 01:24 PM
5150steves's Avatar
I just got LED replacments for my bulbs in the taillights and the blinkers go faster now.
I want toem to go back to what they were and this was what the guy at the LED place said.
"Sometimes this can be solved by replacing your flasher with a heavy dutyelectronic unit.
Our Load Resistors will always solve the problem but they are harder to install."
Any idea where I can get a heavy duty flasher and what I ask for?
Steve
