light bulb behind ac knob
Old Sep 16, 2004 | 10:46 AM
kruck's Avatar
light bulb behind ac ****
Has anyone has to replace the bulb behind the ac control ***** in a 99 f150? I was wondering, if someone had, I'd like to know what the easiest way to access it is.
thanks!
Old Sep 18, 2004 | 07:09 PM
dasmaz81's Avatar
yep, it is easy...
you have to remove the trim around the radio and the temprature control. Then you should see some bolts... I think there are wither 2 or 4 that hold it on. You may or may not have to remove the radio. pull it out... (you will need to unplug the wires)...
In the back you will see 2 twist sockets that hold the bulbs. Untwist, remove bulbs, replace bulbs... then reassemble.
should take 10 - 15min....
