Factory tow light plug
Old Sep 5, 2004 | 12:35 PM
macojoe's Avatar
Question Factory tow light plug
I have a 1998 F150 XLT 4X4 5.4 Triton, with tow package.
I bought this used just a month ago. I have a camper and a boat. The truck has a 7 way round plug from the factory on it. But it does not seem to work??
I have put a tester on every connection and there is no power?? I have gone to the plug above the spare tire and there is power on one side of it, which I belive is for the regular lights? But the other side is dead??
I have checked all the fuses and there is nothing blowen, same it the fuse box under the hood??
What am I missing?? Thanks guys!!
Old Sep 5, 2004 | 06:15 PM
macojoe's Avatar
Also the light plug has never been used!! Neither has the hitch!
So it must have been this way from the factory?? The old owner says he never had a use for it so he does not no eaither??
Thanks again
Old Sep 5, 2004 | 07:07 PM
Old Timer's Avatar
Did you fix it? If not, sounds like maybe relays missing? Look in your o.guide book. Besides fuses, it also takes relays.
Also I think you may find the 12V chg. circuit will have no power w/e. or ign. off. Look for updates.
Good luck...OT
Old Sep 5, 2004 | 07:55 PM
macojoe's Avatar
Nope I have not fixed it yet. I will look in the book to see what it says. I have read and checked all fuses and they are all fine. But I did not check relays.
Thanks I will keep you posted!!
Old Sep 5, 2004 | 09:52 PM
Yankee7985's Avatar
You need to check to make sure the relays are even installed in the fuse block in the engine compartment.
Old Sep 5, 2004 | 10:53 PM
macojoe's Avatar
well according to what the book shows everything is were is belongs??
I have never seen anything like it before?? Then again I have never anthing this new before??
Old Sep 5, 2004 | 11:36 PM
Yankee7985's Avatar
Did you check the little fuse block outboard of the large fuse block under the hood? It is about .750 wide X 2" long, and probably has a piece of electrical tape over it. Check these fuses.
Old Sep 6, 2004 | 10:05 AM
macojoe's Avatar
I found the problem!! Yes it was a blown fuse. But under the hood there are 3 fuse boxes!!
1. is the big one with all the fuses and relays
2. is the smaller one that Yankee said to look at.
3. when looking at the 2 boxes that are close toghter you can't see the third one under the lip of the fender. It has just 2 fuses a 5 amp and a 20 amp and the 20 was blown!!
Thanks all for your help!!
