reverse lights / cruise control
Old Aug 29, 2004 | 10:53 AM
wod99's Avatar
94 F-150 - the fuse for the reverse lights keeps blowing. Also the cruise doesn't work but that is the same fuse so it sorta makes sense. Is there any easy way to check for shorts?? any other suggestions??
Old Aug 29, 2004 | 11:09 AM
wiss's Avatar
Grab a voltmeter and perform a short test on the fuse and wire. You may need someone to put it in reverse to kick on the lights so you can read the meter. Look around the web for instructions for the instructions that came with the volt meter.
Good Luck!
