power windows quit
power windows quit
Please help.
94 F-150 and neither of the power windows work! Owners manual says 20 c.b.. I replaced that and they still don't work. I've tried from both switches and from drivers and pass door...Nothing! Any suggestions??
Okay, did you do anything that caused this > new speakers, adding any mods that you had to cut into a wire?
Do you have a volt meter and know the fuse plg for the windows? Test to make sure there is 12 volts there then also test at the door. This involves taking the inside panel off... You will be able to narrow the problem to an area. Look around the forum to see how to take the door apart.
It sounds like a fuse problem if BOTH windows have stopped working.
Did they both quit at the same time? Did they start acting up prior to them quiting? Is anything else not working besides the windows?
