99 f150 4.2 v-6 wont turnover
Went to start- nothing happened- lights, everything else looks up to power. Read somewhere to touch the two starter relay teriminals together- it fired up. Is it the starter relay or something else-- thanks
If shunting the solenoid terminals got it, then it could be your solenoid. Did you shunt the big terminals, or a big and a small? Try putting a screw driver between the small terminal and the big terminal feeding the battery. If it works like that, then your problem is else where.
