AC mode changes at half throttle…
Old Aug 9, 2004 | 04:54 PM
mikefox670's Avatar
AC mode changes at half throttle to Defroster mode. Leaving up on the throttle restores the air back to the dash registers.
Need some help.
1998 F150 XL 4.6L
Old Aug 10, 2004 | 01:45 PM
mdstud's Avatar
It sounds like you have a vacuum leak somewhere.
Old Aug 11, 2004 | 05:17 AM
mikefox670's Avatar
Problem found...
Problem found on the passenger side firewall. A black, spaghetti size, line running from a small vacuum check valve to a rubber grommet in to the firewall. The line was leaking about three inches back from the firewall due to abrasion. I took a piece of heat shrinkable tubing and slid it over the leaking line for a temporary fix. I’ll put a new line on later.
Thanks to all who replied.
