Headlight De-Assly
Old Jul 21, 2004 | 10:37 AM
nashr1's Avatar
Headlight De-Assly
Is there someone that might have photo's on the de-assembly and removal of the headlamp? 1999 f150
Old Jul 21, 2004 | 03:33 PM
Florida-150's Avatar
I assume you are talking about the headlight 'shell' that the bulb is housed in?
If so, I dont have pictures, but it is very easy to remove.
There are two metal tabs on both sides of the headlight assembly. You simply pull upwards on these until you feel a snap (they can be fairly tight). Once you have done this either stick your fingers down around the wire harness and push forward on the assembly or try to grab it from the front and it should slide right out. Once you have done this, grab the plastic retaining 'nut' and turn in counter clockwise to remove the wiring harness and bulb. Good luck!
