Projector headlights
Old Jul 4, 2004 | 08:22 PM
Mud_Slut's Avatar
Question Projector headlights
Added some projectors to my 98 f150 4x4,simple plug N play..
Just 1 problem with the low beams on my hibeam light comes on in my instrument panel...then i turn on my hibeams on lights go really dim check all connections seem to be fine ...any one have any ideas to whats wrong?
Old Jul 15, 2004 | 06:15 PM
swoop19's Avatar
I am having the same problem. Have you figured it out yet? I bought some headlight assemblies with the blue leds and halos around the projectors. The inside lights (which seem to be the high beams) are what turn on with normal operation and the outer ones (not as bright or high) go on when I select high beams and the fogs also turn off. Just like you said. Plug and play. I didn't change any wiring and the headlights came already wired with the correct plugs. Any help is greatly appreciated. Thanks, Jeff
Old Jul 18, 2004 | 08:49 PM
ironhat's Avatar
So, what brand of headlights did you guys install? I was just about to change mine but this has me spooked!!
Thanks,
Chiz
Old Jul 19, 2004 | 03:09 PM
Mud_Slut's Avatar
The headlights i got are from www.mytightride.com they are the
Sonar's F150 and Expedition Projector Headlights
shown with the black housing. had no help with the problem so far and still dont know why they dont work correct..So I guess I'll take this as a learning lesson...If find anything out Jeff Please let me know..
later
jess
