head light ajustment ?
I installed new bulbs in my headlights 2002 f-150 at 25 ft. the right side light is higher by 18 inches is this normal .I didn't look before i took them out. should both be level? thanks
They should be both level.
Park on a level surface 25 feet from a wall.
Measure the height from ground to headlight centre (beam of light)
go to the wall and measure the same height, that is where the beam is suppose to be centered.
