wiper motor
Old Jun 12, 2004 | 03:38 PM
ojshjs's Avatar
wiper motor
Just bought a 1987 Lariat 5.8L. My first Ford. The wipers don't work and I've traced it back to the motor. Makes a little noise like its trying. For the life of me I can't get it off!(the truck).
Could really use some advise. TIA OJS
Old Jun 17, 2004 | 04:12 AM
DIESELMAN's Avatar
wiper motor
TO REMOVE YOUR WIPER MOTOR,FIRST DISCONNECT YOUR NEGATIVE BATT. CABLE(OPTIONAL)REMOVE WIPER BLADE ARMS FROM THE PIVOT SHAFTS,REMOVE YOUR COWL GRILL SCREWS(MAKE SURE YOUR HOOD IS OPEN)BE CAREFUL TAKING OUT YOUR GRILL,DISCONNECT YOUR WASHER NOZZLE HOSE AND REMOVE YOUR COWL GRILL LOOK DOWN THROUGH WHERE YOUR GRILL WAS AND TAKE THE CLIPS THAT HOLD YOUR WIPER ARM LINKAGE TO THE WIPER MOTOR OFF,REMOVE THE THREE MOUNTING SCREWS AND TAKE OUT YOUR MOTOR,INSTALL IN REVERSE ORDER,GET YOU A CUP OR SOMETHING TO PUT YOUR SCREWS AND CLIPS IN SO YOU DON`T DROP OR LOSE ANYTHING...GOOD LUCK
