power windows on a Lightning
Old May 26, 2004 | 03:17 PM
LeoGSVT's Avatar
ive posted a couple of times and had no help at all....where is the fuse for my power windows on my 2000 Lightning...im looking at this manual for a newer L. (dont know if its the same or not) and it says Circuit breaker 601 is for power windows...but when i look under to hood at it..it looks like a blank spot and nothing is there.....im so frusturated....i have no power windows along with no A/C in this 100 degree florida heat...please help someone.....
Old May 27, 2004 | 12:04 AM
SSCULLY's Avatar
When I pull down the 2000 F-150 owner's manual it shows the power windows as fuse # 110 in the power distribution box ( under the hood ).
It is a 30 A Maxi Fuse
The A/C could be a few things.
1. the A/C clutch relay is half relay 204
2. The A/C clutch is fuse #13 15A
Those are what the manual online show for the 2000 F-150
https://www.fleet.ford.com/maintenan...ucks/F-150.asp
Let us know what is up with these, and we can move forward.
You could have a problem aside from a bad fuse causing this.
Good luck
Old May 27, 2004 | 12:06 AM
R8rvectors's Avatar
Info for a 1999 F150 may help:
The power window fuse is #110 (30 amp).
Fuse #103 (50 amp) can also cause the windows to fail if it blows.
Position #601 is not used.
