turn signal
Old May 4, 2004 | 12:34 AM
PAFISHER's Avatar
turn signal
98 150 24000 miles all orginal except front brakes
my problem is turn on turn signal all the way on to make left turn signal flashes really fast & only back light blinks.
turn on turn signal like you would on freeway ( just before it would lock ) left turn signal works fine.
Old May 4, 2004 | 05:44 AM
momalle1's Avatar
Sounds like the multifunction switch.
Old May 6, 2004 | 09:04 PM
regman's Avatar
HAd same problem in my 97 screw. After third or fourth time of replacing what I thought was a bad bulb, I replaced the socket the bulb goes in. Bulb didn't appear to be fitting snug enough. Less than 10 bucks, and NO more fast blink! Good luck.
Old May 8, 2004 | 07:59 AM
Ted'98's Avatar
PAFISHER - before you buy a new switch, check out the pictures in my post on this other thread.
Fix for turn signal
I had the exact problem you outlined and after a few minutes of cleaning all the green gunk out of the switch, it works perfect now.
It certainly is worth investing if this is your problem, I think a new switch is in the $50-$60 range.
Old May 8, 2004 | 09:09 PM
regman's Avatar
Lightbulb
I'd start with the $10.00 item prior to dropping 50-60 on a switch.
Although, the choice is yours.
